looking for maps 3.0 duratec
Posted on this once all ready. I dont think i had the right title. Im looking for VE and timing maps that are as close to factory as possible. Or a screen shot of the factory maps.
Re: looking for maps 3.0 duratec
First... do you have a means of converting the way the factory ECU stores its maps into ones for MegaSquirt?
If i had a screen shot. I can put the values into a MS maps by hand and build it that way.
Often factory load numbers are so different to interpret that you're best building a map by hand following the manual for your MegaSquirt variant.
I understand that the factory load is diff to interpret. But I don't mind. I would like to see one, and also the timing map.
No body has one of these.
Is it because nobody wants to share. Do I have to pay for info. Or there is just no body out there tuning these.
I'm not sure anyone present on this forum has cracked the factory maps. Most of the people here are more into replacing factory ECUs than hacking them.
