I am new to this ECU stuff, I have a megasquirt, I am looking to run the engine off the vacuum sensor, can anyone help with a base tune for a factory Toyota 1NZFE please or can anyone recommend a tune that will get it running?
Many Thanks in advance
Bruce
Toyota 1NZFE
Re: Toyota 1NZFE
I haven't tuned one, but I can post a link to the documentation for how to put together a startup map if you post what MS variant you have.
Re: Toyota 1NZFE
Anything is worth a try, just out of interest how come no one has a data base of base tunes for certain engines that could be downloaded to get you started?
Bruce
Bruce
Re: Toyota 1NZFE
We have base maps posted for the MSPNP line:
http://www.megasquirtpnp.com/mspnp2_maps.php
http://www.megasquirtpnp.com/mspnpp_maps.php
They could be potentially used for other MS variants as well. However, the shear number of engines that MegaSquirt gets installed on - and the number of these engines that are running decidedly non-stock ignition setups and other things that require major settings changes - means that it would be a Herculean task to cover the whole range of engines that MegaSquirters are running. Especially if whoever's hosting the tunes wants to vouch for them and confirm they work well, rather than just collecting random tunes that somebody says works for them.
Re: Toyota 1NZFE
The upshot of which is that finding a "basetune" that will work for you is as likely as winning the lottery. With engine management there are really no shortcuts to success.
When you say " run the engine off the vacuum sensor" I assume you mean use a speed density tune and do also intend to run all the other required sensors as well as MAP.
Cheers Luke
Cheers Luke
Re: Toyota 1NZFE
My megasquirt has megasquirt 1 extra label on it, when I go to check out the info on this model I get page not found
http://www.msextra.com/doc/ms1extra/MS_ ... _Index.htm
Can anyone help with a working link to a manual?
Bruce
Bruce
Re: Toyota 1NZFE
Cheers Luke
Cheers Luke
