6.0 ls backfire in fully seq. and cop
the car runs on wasted cop and semi sequential. When i put it to fully seq and cop the car wont start and i had a backfire when i tried to give it gas. here are some data logs.
Re: 6.0 ls backfire in fully seq. and cop
just got it running in fully sequential but the rpm sync in tunerstudio shows red then turns green.
i attached the datalog and reason #91 comes up.
Shows a constant sync loss in that log, you'll have to look up reason 91.
Graduate of EFI University.
Do you have a composite log of what's going on now that it is sort of running?
found out the problem. The cam sensor wasn't tightened down all the way, and a the cam sensor pigtail had a wire exposed. tightened the cam sensor down and ordered a new pigtail. Problem solved.
