Mustang Starter tables
mr_minnis
Post by mr_minnis »
Hello,
Attached are a couple tables I am currently using on my Ford 302 that is sequentially fired, using Mass Air (VE1 as trim table). I'd like to share with others as a starting point with their tune. Keep in mind My MAFload at idle is 15-20, My MAP value on same engine at idle is 35. You may have to adjust the X and Y values, My redline is 6000. I have not dyno'd the engine, this is a daily driver.
Remember a good tune for a daily driven engine is a positive combination of Power, Driviabilty and Economy.
The AFR table is in Lambda.
I'm not responsible for engine damage that may occur. Please review before saving changes to your tune.
mr_minnis
Re: Mustang Starter tables
Post by mr_minnis »
please post any feedback.
you can set your project to lambda and change it back to afr. That's what I did. Its a lot easier for me to see what is going on in afr.
