maf/map
maf/map
MS3 with MS3x
my maf handles only 250 or so HP. I also have a map installed that is a 5 bar.
I was using table switching with MAP but want to take advantage of the maf for normal driving...is there a way to table switch using maf? Or better yet switch to MAP when under boost?
thx guys
thx guys
Re: maf/map
Use table switching with MAP as the trigger.
Re: maf/map
I currently have MAP for my table switching. When I select MAF as control algorithm the VE dual table gets grayed out. Can you explain how I would use MAF for normal driving and MAP for boost? I attached my MSQ I am using for MAP table switching. (ignore the table values, this tune hasn't been tuned yet, I just wrote it)
Should I not use "table switching" but instead use "dual fuel switching"?
This is something new so I apologize for asking simple questions. Its not critical for me to do it this way, I just wanted to give it a shot. I like the MAF for NA driving and since this truck has it built into the TB I thought I would make use of it.
Thnx.
Thnx.
Re: maf/map
I'm away from my computer right now so I can't check, but I believe you can use blended tables to do this.
___________________________________________________________
If nothing breaks, you're not trying hard enough...
Datsun 280Z
ITB
Turbo
MS3 + MS3X
Datsun 280Z
ITB
Turbo
MS3 + MS3X
Re: maf/map
I might want to do the same thing. Please post results when you get it figured out.
Re: maf/map
I've had a rummage through your .msq, and I *think* this is how to do it:
Under [Basic/Load Settings][General Settings],
Under "Fuel Settings", fill VE1 with 100 up to your switchover point (100.0 kPa?), and zero from 100.1 kPa and up. Tune VE2 normally from 100.1 kPa and up, but set everything 100.0 kPa and under to zero.
Under [Table Choices][Table Switch / Dual Fuel], select "Fuel Table Switching" => "Off"
- select "Primary Fuel Load" => "MAF"
select "Secondary Fuel Load" => "Speed Density"
select "Secondary Fuel" => "Additive"
Select " "Multiply MAP" => "Multiply
Re: maf/map
That's not the type of blended tables I was thinking of, the settings above use a secondary modifier table.
I'd use the "blend curve" feature. See "Secondary algorithm blended table" here:
http://www.msextra.com/doc/pdf/html/Meg ... 3-104.html
Re: maf/map
i actually have done this. i had it setup so an output fed an input and also had a manual switch inbetween so i could go sd at all times at a flip of a switch. yes use table blending. the only problem i had with this is that mat is handled differently whth maf as primary
Re: maf/map
jsmcortina wrote:That's not the type of blended tables I was thinking of, the settings above use a secondary modifier table.
Thank you.
Where can I find that whole document?
NM....got it.
