RZ350 2-stroke trigger configuration questions
I have a 1985 Yamaha RZ350, 350cc 2-cylinder 2-stroke motorcycle, that I am converting to EFI. I have made good progress getting my Microsquirt wired up with all the sensors, running MSExtra 3.3.2. I am starting to do the configuration in TunerStudio; all the sensors seem to be reading correctly, MAP, IAT, CLT, TPS. I havent hooked up the fuel pump just yet though. Using R6 throttle bodies with 230cc/min injectors.
For now, I am using the MS for fuel only, keeping the stock ignition. The ignition system has two triggers on the flywheel and a single VR sensor. It gives two ignition events per rev (obviously this is a two-cylinder two-stroke so that is necessary, 180deg apart). It is wasted spark. In TunerStudio, I am planning on setting up to use '2 Squirts Alternating'.
My question is, how do I tell TunerStudio what the configuration of the ignition triggering system is (ie. two triggers = one rev)? The only place that I can see option like this is under the 'Ignition Settings' >> 'Ignition Options/Wheel Decoder' page. Do these setting also apply to injection as well as ignition (which i am not using)? If so, what other settings on this page will affect the injection timing, if any?
EFI and Turbo Yamaha RZ350
Microsquirt with MSExtra 3.3.2
Re: RZ350 2-stroke trigger configuration questions
For a situation like this, with two 180* teeth and one VR, I would say there isn't much difference between calling it a 2-0 wheel and Basic Trigger.
Edit - Actually, I don't think you can use a toothed wheel without a missing tooth OR a cam signal, so Basic Trigger is what you'll need. And yes, you can use control both injection and spark with that; you'll need to determine your trigger angle for ignition.
Ok, great, thanks for your response. Does the ignition table (spark advance) also affect the injection timing?
No. The injection timing table is used for that.
Thanks James. That was my initial thought but that option is greyed out in TunerStudio.
Sequential injection is only available with certain input trigger arrangements that provide enough information for the ECU to run sequential. Typically this is a missing tooth wheel on the crank. (4 stroke engines want a cam sensor also.)
Ok, so with my triggering setup I would use 1 squirt Simultaneous?
I'm still a little unclear as to how the controller know that it will see 2 trigger events for one crank rev. And if I use 1 squirt simultaneous, how does it know NOT to inject when it sees the 2nd trigger event. Does it know that based on the fact that I select '2-stoke', '2-cylinder' and 'Even Fire'?
Yes, that's the idea.sweet_baby_james wrote: Does it know that based on the fact that I select '2-stoke', '2-cylinder' and 'Even Fire'?
ok, so I was just over thinking things I guess! Still have the injection timing table greyed out though. :/
You can't use sequential injection with the setup you have. So the table will remain greyed out.
I changed to simultaneous and still have it grayed out.
This is why:
jsmcortina wrote:Sequential injection is only available with certain input trigger arrangements that provide enough information for the ECU to run sequential. Typically this is a missing tooth wheel on the crank. (4 stroke engines want a cam sensor also.)
Got it. So the injection timing is fixed with my existing setup.
I should probably look into getting an additional flywheel and mounting a 36-1 wheel to it. That would mean I have to use the MS for ignition and fuel. New coils required for that I guess.
I would like see videos for this machine run megasquirted ! i love yamaha rd350 lc !
Vw Santana AP 2.0 - MSII PCB3.0 Extra 3.2.1
Here's a link to a short video on my Instagram. Bike has Microsquirt controlling fuel and ignition at the moment. I have also got it wired to control turbo boost pressure but that needs tuning first.
https://instagram.com/p/-NjPDkvgxI/
Hi James, I know this is an old post but I am heading down the same route as you by fitting a microsquirt to a RD350 YPVS. The question is have is how did you connect the VR up? I have followed a really old post by a guy called Steve Murphy but he was using a Mini-MS, He mentions using a HEI four pin module but in the Microsquirt 3.4 manual it says to use 7 or 8 pin. I have also been told I can connect the VR1IN+ & VR1IN- diectly to the pick up on the flywheel.
If you could point me in the right direction then I would really appreciate it.
Dave
Dave
sweet_baby_james wrote:I have a 1985 Yamaha RZ350, 350cc 2-cylinder 2-stroke motorcycle, that I am converting to EFI. I have made good progress getting my Microsquirt wired up with all the sensors, running MSExtra 3.3.2. I am starting to do the configuration in TunerStudio; all the sensors seem to be reading correctly, MAP, IAT, CLT, TPS. I havent hooked up the fuel pump just yet though. Using R6 throttle bodies with 230cc/min injectors.
Those are cool bikes. I still have mine, a 1984, the 112'th one built, according to the serial #.
You will be shocked how big the injectors need to be on a two stroke. I ended up at two 800 cc injectors to feed a 800 cc motor at 7300 rpm. It has to do with you have twice as many injector openings and closings per engine revolution compare to the more common 4 stroke install.
Andy
Andy
I welded a 20-1 trigger wheel to my stock YZ250 ignition rotor and am using a second pickup coil (from a YFM350) just for the Microsquirt. If you want to do ignition timing I'd probably recommend going that way.
However some have used the standard 'long tooth' type trigger setup with success:
http://74.124.198.224/~micro/viewtopic.php?t=23246
http://74.124.198.224/~micro/viewtopic.php?t=23076
Yamaha YZ250 - Microsquirt V3 - Madhu PWM Fuel Pressure Regulator - 14point7 Spartan Lambda Controller 2
