Need someone to check out my tune
I have my data log I'd like someone to look at... i haven't got time right now to put into it but I moved the car to my storage for the winter and with everything else going on might it be able to look at it for a few weeks so any input before I get to it would be greatly appreciated. ..
Had to zip it because it was 4.6 mb which is to big to upload
Re: Need someone to check out my tune
It's easier to look FOR something in a data log than to just look AT the data log. Are there any particular issues the car's having that you would want people to check up on?
Knock seems to be my issue.. it's a little slow to start but I know what to do about adjusting that. Just the knock I'm concerned about
I got a stock sensor for a taurus sho with the adapter board and I think I had the knock set to around d 5.50 hertz area
When the knock sensor is set to "internal", you will bypass the conditioner on the adapter board.thecrew2999 wrote:Knock seems to be my issue..
Try getting a full throttle run with a conservative spark table and see what your numbers are there, then set the threshold number a bit higher.
I would need a data log of that issue to offer suggestions there.it's a little slow to start but I know what to do about adjusting that.
Thanks Matt I'll try that out. The starting issue I'll get worked out I know how to fix that easy i just haven't had time yet with my daily driver junk breaking on me.
How will I know I got the right frequency?
There are a number of calculators out there that go off bore size.
Yeah I got between 5 to 6 Hertz ... just thought that was pretty broad
