I am sorry for this question,, just want to make sure I can make changes and burn on these opened tables while the engine is running.
Basic setup >table ARF Table 1
and
Basic setup > Spark Advance Table 1
just want to make sure,, getting ready to tune and don't want to make any BIG mistakes.. I have read and read till I'm blue in the face..
I think the only place not to burn with the engine running is
Tool > Calibrate Thermistor tables
Tools > Calibrate AFR tables
Again sorry for the dumb question!!
Thank you for your time and patience!
Tinker
can I make changes on these pages while running?
TUNER STUDIO V2.6.19 MS2/EXTRA RELEASE 3.3.3
72 Vega GT ls1/ms2
Tinker
72 Vega GT ls1/ms2
Tinker
Re: can I make changes on these pages while running?
You can tune those tables on the fly without burning as they are in RAM memory. A burn will save the table values to Flash memory and will often cause a slight stumble on MS2 so you do your adjusting without burning and then when the engine is unloaded and idling burn the changes to Flash to make permanent.
Cheers Luke
Cheers Luke
Thank you Luke much appreciated!!
72 Vega GT ls1/ms2
Tinker
72 Vega GT ls1/ms2
Tinker
