Supercharged IAT location
Fueler
Post by Fueler »
Roots supercharged Chevy with Enderle throttle body/hat, 8 injectors above blower.
What is the consensus on the IAT location, Above or below the blower?
Pros and cons of each?
dontz125
Re: Supercharged IAT location
Post by dontz125 »
The IAT has to report the air temperature actually entering the cylinders. In a situation like this, with or without coolers, you want it to be after the last heat-transferring device.
Fueler
Post by Fueler »
That would be the logical location I agree.
I have also seen several similar setups with the IAT above the blower with the injectors.
These usually were tied into some kind of plug and play non tunable ecu.
Wonder what their thinking was as to why that location?
Was it just to make a "package" or was there a tuning reason?
elutionsdesign
Post by elutionsdesign »
If it was a MAF (mass air flow) based system the IAT placement is much less critical, once you know the mass of air moving through you're no longer using the ideal gas law to make fuel calculations.
Graduate of EFI University.
Fueler
Post by Fueler »
Not a MAF application. The best example I can think of is here.
http://www.force-efi.com/specials.htm
elutionsdesign
Hmmm, I'd guess it is a packaging issue, meaning they can package it there and you don't have to be drilling holes on the pressure side of the manifold.
slow_hemi6
Post by slow_hemi6 »
They probably just don't want to/ can't deal with heat soak start up issues. If you have the sensor down there in the oven then you will have heat soak but under boost you do need to know the true temperature of that intake charge. I have seen guys run a second ambient IAT temp sensor for start up and change to the MAT sensor after start. Mine being N/A, I just fudge the curve. lol.
Cheers Luke
Fueler
Post by Fueler »
That sounds like a good possibility of what probably happens there.
Any idea of how one would go about getting an MS2 extra to see the 2 different IATs? 1 at start/warmup and the other at Run.
slow_hemi6
IIRC the guy had a change over relay driven by a programmable output. Probably used the "seconds" output channel to switch over after a given elapsed time. That's probably what I would try if I needed it.
Cheers Luke
knightrous
Post by knightrous »
slow_hemi6 wrote:They probably just don't want to/ can't deal with heat soak start up issues. If you have the sensor down there in the oven then you will have heat soak but under boost you do need to know the true temperature of that intake charge. I have seen guys run a second ambient IAT temp sensor for start up and change to the MAT sensor after start. Mine being N/A, I just fudge the curve. lol.
This isn't a bad idea, however I reckon it could be implemented a bit better.
Run two temp sensors, one as a Intake Air Temp (IAT) sensor and another as a Manifold Air Temp (MAT) sensor.
Always use the IAT sensor until you exceed 100kpa (or based on a curve) then begin using the MAT sensor.
This would allow you to avoid any heat soak issues and still be able to run Speed Density correctly.
As a bonus, you would also have the ability to see the difference between the IAT and MAT temps side by side in logs.
'89 Toyota MR2 AW11 - 1MZFE 3L V6 - Need to finish car before ecu :(
'89 Toyota MR2 AW11 - 16V 4AGZE - DIYPNP 1.5v
'90 Toyota MR2 SW20 - 1MZFE 3L V6 - MS3X
Fueler
Post by Fueler »
I have been looking around TS to see how to implement this dual temp scheme and am failing to see the light.
Is this possible to pull off?
elutionsdesign
As mentioned, use a programmable output to drive a relay that switches from one sensor to the other. Go to "Boost/Advanced" and then down to "Programmable On/Off outputs".
sdtib
Post by sdtib »
This sounds like it might be a great (but complicated) solution to my problem.
http://www.msextra.com/forums/viewtopic ... 34&t=56915
@fueler...pros and cons of IAT location from my perspective are in that post
megaman3
Post by megaman3 »
knightrous,
you had mentioned that you posted some Eagle files for the megasquirt. I cannot find them anywhere. can you repost or send a link to them? Thanks.
