I'm trying to get constants right but 1 simultaneous will not work.
It'll remain at 25% dc with 1000cc injectors 14pw, it's crazy.
VE @ 0. Dead time a @ 0.10. It will not lean out at all. I can not figure it out.
Then the person tells me one of his injector banks is fried so he's using the other one.
It'll run on 2 alternating BUT the constants are really wonky.
like 14 reqfuel and 1.93 deadtime and it'll run ok. obviously not the right dt.
My question is does 1 squirt simultaneous need a specific bank to work and if it does I'm thinking it's
the one that is fried. Also would that be why using 2 alternating is sorta weird?
1 simultaneous need specific bank?
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
Re: 1 simultaneous need specific bank?
It's been said before, in other threads... surely it would easier (and more reliable) to fix the board! Then, of course, there is the ever-popular:
So if it's been said before, in other threads.... U should know, correct?
Can you let me know I haven't seen these threads you talk about.
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
It uses both banks and fires them at the same time. But if it works in alternating mode then you may need to update your req fuel or your dead time.
Then it should still work even if he has all 4 wired to just 1 bank correct?
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
It should. But now would definitely be a good time to upload the msq and log (as requested above) so people can see if there is something in the settings that may cause the issue.
