Idle weirdness question
hi all i write here so i don't have to open a new post
someone is expert to tune idle with pwm 4 wire valve?( it has 1 inj on throttle body, 4 cyl petrol engine)
i have this on my car , and the idle bounce..
the autotune tuning the idle very high so i manually change che ve table but write 0 in most cell without solve problem
request fuel is properly calculated , and inj parameters are right
thanks for support ,sorry for my poor english !
bye
bye
Ms2 v3 Blue Board - Extra code updte
Wasted Spark, Stepper idle -> No clock, led, pwm flyback circ. , Pullup resistor, trigger off coil neg. term. ->F.E.T. protection circ. -> Vr, Hall, Opt. circuit -> Vr Jump -> Std flyback ->Dual Map, Table -> Launch control -> Tacho Out
Re: Idle weirdness question
All 4 wire IAC valves I've seen have been steppers. If you have wired it up as a PWM valve, that could be your problem. If this really IS a 4 wire PWM IAC valve, please post a detailed description of how it works, as I've never heard of such a thing but it could theoretically exist.
I would recommend seeing our article on idle tuning:
http://www.diyautotune.com/tech_article ... uning.html
And this one on stepper valves.
http://www.diyautotune.com/tech_article ... r_iac.html
thanks for the answer
i have a 4 wire stepper valve
i ll reading the articles , thaks !
ok my car now run on idle at 15.2 about ( i set the afr table for this , a little economy) and work well
the problem is that the idle is on 1100 1200 rpm , instead 600-800 as requested the afr is ok , the stepper idle valve is fully closed (0 steps) so i don't know how lower the idle.. in this cell the advance is about 22°, 20-30 kpa row (1200 rpm)
thanks a lot for your time
Check for a vacuum leak and see if the throttle can close any further.
ok , the throttle has stop screw , but i can't change that registration because car has to run with std ecu..
maybe a wrong stepper setting??? in idle warmup duty step graph the value start from 57 and finish to 0
maybe with new firmare the count is inverted, an i run at idle with fully open stepper?????
Make sure you are using enough retract steps.
ok this is the question
the stepper motor close idle air flow when it open almost fully
now start from 57 steps and goes to 0
if i put 150 steps the car accelerate a lot and leaning afr , so 0 is the minimum ( i think almost fully opened, closing the air flow)
when stepper goes to 0 the car stay steadly at 1200 rpm at stoich
about air leak it think that is all ok because with stock ecu it goes very well
may i have to lean a lot afr????
help.......
help.......
i have solve the problem , just tweaking the home steps
but i suggest to improve stepper knowledge, maybe with a good tuning settings , always me and some friend with EU cars are confused about open and closed concern......
