bump box staging
bump box staging
i was reading in the yellow bullet that ms3 supports bump box staging. where would i find that?
Re: bump box staging
Under Launch Control / 2 Step / 3 Step / T-Brake in the Advanced Engine menu. See page 227 of the MS3-Pro manual for details.
i have the transbreak button input right (js11) per manual. i dont know what to pick for transbrake ouput. can't find it in the manual. i saw this post http://www.msextra.com/forums/viewtopic ... 25&t=50135 and do i need alpha 5 firmware to set the release time and on time? there is under throttle stop output a place for these settings.
It's in the current 1.3.3 firmware; no alpha code required now. You can use one of the MS3X mid current outputs to drive the solenoid as long as it takes 3 amps or less.
i down loaded 1.3.2 firmware already. can i put the b/ld jumper in to down load the other two firmwares (1.3.3, 1.3.4) or do i have to erase the 1.3.2 first?
You do not need the boot jumper to reload firmware unless you've put in some weird setting that crashes the firmware without making it throw an error code.
so i would just load the two patch firmware with out erasing the 1.3.2 firmware?
