Does anyone have a similar msq file handy that you could upload? I have a sbc 383 stroker with 8 60# hi z injectors on ms2x running fuel only.The car used to turn on idle and rev up just a bit rich @ operating temp about 6 months ago, i finally got around to messing with it and i guess i hit something and now its all messed up . I am still getting a tach signal and the car turns on with some carb cleaner in the TB but im not getting a pulse to the injectors. I am running a digital programmable msd box for ignition fuel pressure is ~43psi.
sbc 383 stroker
8.5:1 comp.
victor jr intake
elbow to ls style 90mm tb with gm iac
sbc 383 60# injectors fuel only MSQ
Re: sbc 383 60# injectors fuel only MSQ
Better if you post up your tune and a log file of it trying to run.
Graduate of EFI University.
post your msq and we will gladly take a look to see what might have accidentally been turned on or off..
