CORRECT dwell settings?
What are the CORRECT dwell settings for a small block Chevy?
One article says minimum for HEI4, another says to use dwell settings, WHICH ONE IS IT?
Megasquirt 2 V3.0 Running Msextra 3.4.2. in a 1989 Camaro RS .48AR/60mm Turbo 3.4L/700R4
Boost control, Fan control, Stepper IAC, Launch/Antilag, Working on the GMDIS, and Methanol injection
Re: CORRECT dwell settings?
What kind of coil(s)??? The SBC has had many, many different ignition systems over the years... and that is just the stock sytems!
"Minimal for HEI4" should be used when a 4 pin HEI module is controlling the dwell. And at no other time.
7-8 pin HEI. The DIYAutotune site says to use minimal for HEI4 setting, doesn't clarify which HEI module however.
MSD Blaster, 4 wire coil. HEI 7-8 pin. Running boost with a smaller plug gap. 82-92 sbc.billr wrote:What kind of coil(s)??? The SBC has had many, many different ignition systems over the years... and that is just the stock sytems!
Please post a link - I thought I'd fixed that.WillExoIX wrote:7-8 pin HEI. The DIYAutotune site says to use minimal for HEI4 setting, doesn't clarify which HEI module however.
http://www.diyautotune.com/tech_article ... _v8_v6.htmMatt Cramer wrote:Please post a link - I thought I'd fixed that.WillExoIX wrote:7-8 pin HEI. The DIYAutotune site says to use minimal for HEI4 setting, doesn't clarify which HEI module however.
All the way at the bottom of the instructions for MS1/Extra
I'm running 2.9ms dwell on my dads 350SBC with an MSD Blaster coil (round cylinder type, not the SS) and a VB921 driver. It has no spark issues, driver doesn't get hot etc...
Sydney, Australia
1971 Holden Monaro HQ
I'm running 1.4ms so far so good. I do have a plug gap half that of stock though. Was just looking for a good cranking dwell, running dwell, and minimum dwell settings or whatever that last one was.krisr wrote:I'm running 2.9ms dwell on my dads 350SBC with an MSD Blaster coil (round cylinder type, not the SS) and a VB921 driver. It has no spark issues, driver doesn't get hot etc...
