Idle air control
Idle air control
If my idle air control motor is humming because of not having a diode in the wire.if I leave the key on and the motor is running or humming will that cause the idle control motor to burn up? Because one night I left the key on so the idle control had to be humming for a long time and I went to go start the car and the car will not idle.
