Turbo BMW w/gm flex fuel sensor,Running ms3-pro, latest firmware.
I know if I was running speed density, the answer would be table blending, one for a pump gas tune and another for e85 and blend inbetween via the flex fuel sensor. But how about with a maf? I've been running various percentages (E20, E40, E50, E60, E70) and the AFs stay constant throughout with just fuel correction from the flex settings menu which I find pretty impressive. Since with MAF there's just a VE trim table for minor adjustments does it make sense to say take my trim table and scale it by the extra 30-45% needed for e85 and "blend" trim tables based on ethanol %? Just the sound of it sounds complicated. For spark I have the timing addition in the flex menu zeroed and I run another spark table (3) that is also blended, same with boost, table blending makes sense to me for those two. Wanted to get some thoughts so I can decide how to go about fully dialling it in the best way when I head to the dyno.
Thanks!
E85 fuel correction or dual table for MAF?
Re: E85 fuel correction or dual table for MAF?
If you're getting good AFRs on any fuel blend, I wouldn't use the table blending for fuel. But I'd definitely use it for spark.
