It seems to be running significantly richer than I'm telling it to in the "Lamda Table 1". If running Lambda should you not use the Flex fuel correction settings? ANy help would be appreciated. I want to get this sorted out while running naturally aspirated on the dyno before I hook up the turbo.
Files attached. Thanks for the "subtle" reminder Matt....my bad for forgetting them in the original post. I also attached the dyno nummbers. With the cam in the engine it should pull to 7000+.
