Vvti 2jz gte issue
Re: Vvti 2jz gte issue
https://vimeo.com/130693232
I switched from rising edge to falling edge to see if it would change anything and with zero sync loss and timing locked to 10° it jumps from 10° to 20° when I Rev it
1990 supra 7mgte ms3x v3.0
i pulled timing added fuel switched to wasted cop and turned off vvti now it cuts around 5krpm
Can you get a tooth log of the timing jump?
Yes I can if it would help, but I went ahead and switched it back to rising and added latency till it was rock solid which ended up being 80usec it only jumped on falling edge
Should I switch it back to falling and get a log?
Turned back to cop still cuts out around 5k,
added fuel to my ve table till I was uncomfortably rich and the lean spike/miss happens at the same point
Still chasing this problem.... A Friend went through my tune and changed some stuff now it back to only breaking up with boost on and at 4k rpm
Can anyone tell me if my vvti 1 angle is supposed to jump around like it does? If I Rev the car it retards more than it is at idle
A slightly wavy VVT angle isn't that odd - the real problem there is it isn't coming anywhere close to hitting its targets.
Ok, that is probably my settings, I really haven't tried to tune it in much at all because if it had to do with the cam sensor I should be able to run wasted cop and vvti off without a issue, correct?
one other question, Why don't I get sync loss when the vvt changes position? Wouldn't it change how many crank teeth it sees between cam teeth?
Correct, you can run without a cam sensor if you have the VVTi off and are not running anything sequentially. But an out of place cam might make the motor run poorly.Jdmfreak wrote:Ok, that is probably my settings, I really haven't tried to tune it in much at all because if it had to do with the cam sensor I should be able to run wasted cop and vvti off without a issue, correct?
Because the 2JZ-VVTi wheel decoder is intentionally designed to maintain sync at any possible cam location.one other question, Why don't I get sync loss when the vvt changes position? Wouldn't it change how many crank teeth it sees between cam teeth?
Ok, that makes sense, how can I tell if I have a clean signal on my cam? Just the Composite Logger? It looks clean except for a couple blank pages in the log I took up a few posts that was while driving, and while it was breaking up.
Do I need to be running wasted cop with the 2jz vvti wheel setup or am I good running fully sequential?
What frequency should I be running the vvt solenoid at?
Hello, I have a 1jzgte vvti running perfect except for vvti control . I had an issue with it breaking up just like your describing and I found on this forum it needed a resister on the crank signal worked perfect. Could please post a screen capture of your vvti settings?
rusty
rusty
Yep, that is the best bet. You should see three cam pulses for every two turns of the crank.Jdmfreak wrote:Ok, that makes sense, how can I tell if I have a clean signal on my cam? Just the Composite Logger?
It's good for full sequential.Do I need to be running wasted cop with the 2jz vvti wheel setup or am I good running fully sequential?
You may need to experiment with the frequency and PID settings for the solenoid. First use test mode to find a frequency that gives response across a wide duty cycle range, then dial in the PID settings.
here is a composite log while driving breakup happened during this log
could it be i need to adjust the pots a bit more?
Or maybe just add some resistors in line?
everything looks great to me , however there are 2 pages that are blank in the log could it be i need to adjust the pots a bit more?
It looks pretty normal to me. Make sure you're not running any software noise filtering on the cam.
Not running any software, I played with the pots, I zeroed them and adjusted them cw just until the signal is clear, same issue, I am considering zeroing the pots and adding resistors? Think it would help?
Ive added resistors, adjusted pots and found if i add a wire between sensor ground and the vr- my breakup happens at 5k instead of 4k rpm but other than that no change, im about out of ideas
Can you post a composite log and tooth log of the breakup with the latest settings?
