Hi guys...
I was curious, I switched to PWM idle, and got the car idling pretty smooth, after months of fighting with oscillating idle using "always on" on the stepper motor. the problem is, I can't get the car to idle under 1100 rpm. So I block the hole in the TB blade, thinking that I could increase the duty on the PWM idle duty table, but regardless of what I do with the duty table, it makes no difference to the idle. When the car is cold, I have to hold the throttle open until it gets up to about a hundred and sixty degrees before the car will idle. I am thinking my Idle air controller motor is bad, unless there is something I am missing about PWM idle.
Is there something else I need to adjust using PWM Idle Warmup for my idle control? Thanks.
Eric
PWM Idle question
Re: PWM Idle question
the exact same thing happened to me, i was not using the suggested diode in the pwm valve itself. it seems that if you don't use this diode sooner or later a diode in your MS burns.
you should install a 1N4007 diode between positive and signal of your valve (the mark on the diode goes to +12v).
hope this helps.
hope this helps.
do i still need that diode with ms3x it says in the manual just connect it directly
you still need the diode for idle valve
read the note on page 48 in the manual
http://www.msextra.com/doc/pdf/html/MS3 ... .3-48.html
correct but i have the jumper wire wired internally so i shouldn't need it since that wire makes it high frequency capable correct?
