I have a small block Ford where the air temperature sensor is located on the lower intake next to cylinder #5. I'm not experiencing any Heat Soak issues, but I am curious if there is a location which functions better for the MS.
Before the throttle body ??
Air Temp Sensor Location
1992 Mustang Conv,
363" Man-o-War (8.2"Deck), Dart Pro-1,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Innovate DLG-1 (dual WB O2)
Ignition LS2 coil on plug (Crank trigger+ Explorer cam sensor)
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Re: Air Temp Sensor Location
On my very early EFI engine, the ATS was part of the AFM. Didn't need the AFM with MS so replaced it with a plain tube, with the new ATS in that. Not sure it's ideal, though, as it does exhibit heat soak problems.
Having it read air temp just before it enters the cylinder is ideal. Most of my applications have the ability to run water meth so I run all my intake temp sensors about 8 inches in front of the throttle blade and always post intercooler
