idle valve stopped working
I had my iac working (Jeep valve with block from DIYautotune). It worked fine untill now and suddenly the valve won't budge. I tried a larger single step size but it makes not difference.
Ideas ?
Ideas ?
Re: idle valve stopped working
Are you trying this in TS "test mode"? Check for AC voltage across each motor coil, while trying to step. Have you checked resistance on each coil?
I have tested it in test mode, but with the same results.billr wrote:Are you trying this in TS "test mode"? Check for AC voltage across each motor coil, while trying to step. Have you checked resistance on each coil?
I managed to get in working in test mode, but as soon as I went back to the car later on the day it didn't move anymore.
just a question to be sure : could disconnecting the battery when the car is in the garage have any influence ?
Have another motor to try? Disconnecting the battery won't affect anything, that's what happens when you cycle the key off anyways, as far as the idle moto thinks, same with megasquirt
"I managed to get in working in test mode, but as soon as I went back to the car later on the day it didn't move anymore. "
Did you fix or change anything to get it working under TS, or did it just magically heal itself? Does it still work in test mode, while installed in the car? This sounds like an intermittent, and my first suspicion is wring or connectors. Next after that would be soldering on the mainboard, if that was built from a kit.
v 3.57 board.billr wrote:"I managed to get in working in test mode, but as soon as I went back to the car later on the day it didn't move anymore. "
It doesn't work in test mode either at the moment.
