So not knowing what I'm doing and learning as I go, I transposed the maps out of my stock PCM and imported them into Tuner Studio.
The car actually runs really well but a little rich. (I'll play with this)
I am wondering why the Ignition table values are all in red text though? Not that they are red indicating the higher advance but the text itself.
Not that it's required for my question but curious minds sometimes want to know.. It's a nearly stock Chev LT1, I figured the stock tune should be a good place to start even though the tune has smog in mind. Car is a summer daily driver.
Ignition table values in red?
Re: Ignition table values in red?
It appears saving fixes this.. go figure lol
You should really move to TunerStudio, which is being actively supported and developed. Much easier to use than MegaTune.
My bad, it is Tuner Studio
.. Any idea why I can't see where the car is performing on the ignition map? It used to dance around the map and now I just see the map.
VE and AFR are working. Car runs really well, just some annoying things and a lack of a good tune but evidently an ok tune. lol
and perhaps a screenshot of the problem you describe.
the txt in any of the tables (ve,afr ignition and so on) changes colour to let you know its been changed red if its been lowered and blue if its been raised
