1JZ-GTE VVTI MS3X Triumph TR6
Hello,
I have been Lurking around hear for years I have been able to get my car to a pretty good spot. However I really don't know if its good when it could be great?
The Car is a 1969 Triumph TR6 with a 1JZ-GTE VVTI Running full sequential spark and fuel. It Idles perfect and has decent power but...... I'm just not sure about any of it!!!
Primarily I am curious about My ignition Table I really need to understand it better. I am looking for a critique and some pointers. Thanks ahead of time.!!
Rusty
I have attached My current MSQ
Rusty
Re: 1JZ-GTE VVTI MS3X Triumph TR6
if you could also post a datalog it would much better.
Did you check your timing? if you are unsure about the ignition advance table you could always take it to a dyno.
Thanks for your reply I will post a log shortly.
I plan on going to a dyno soon I'm just trying to make sure all my pieces work right before i spend the money.
Rusty
Rusty
You look quite ready for dyno, but a log with various driving will confirm.
Toyota JZX90 Mark II drifter
1JZ-GTE, 12+1 on MS3x, 6x LS7 D514's, 510cc, all stock sensors
Ok it took me awhile took get the logging process down!
Please have a look!
Rusty
Please have a look!
Rusty
Here is a Idle log as-well.
Rusty
Rusty
love the swap looks really good
Thats similar to my swap, just bigger. I have a spitfire with a 4AGE in it. To really get timing set up right get it to the dyno and have a det-can or similar hooked up to listen for pinging.
Take it to the Dyno. Looks ok.
Nice boostcurve on that engine...2k and boost shoots up.
Thx! Guy's
I'll update once its tuned !
RGK
RGK
