Is there anyone in the middle TN are that is good with firm ware upgrades?
I am wanting to try the latest release, my current is 3.2.5. TS 2.6.19.
The reason I am asking is every time I do an upgrade some how I screw it up
and it takes me weeks to get the car running correctly again.
The car is running great now but I would like to try some of the benefits of the new firm ware.
If so you can pm me.
Thanks, David
edit: subject
middle TN firm ware up grade help
