I came across something the other day about timing vs AFR but can't seem to find it.
If I go leaner in the table should I increase the timing or decrease it? Also the opposite (going richer - increase or decrease timing).
What's the general rule of thumb?
Timing vs. AFR
Timing vs. AFR
Thanks you;
Ernie
Ernie
Re: Timing vs. AFR
http://www.innovatemotorsports.com/resources/myths.php
This might be what you are looking for.
Not a simple answer unfortunately.
Nissan Skyline R34 RB26DETT ran MS3/MS3X w/ factory Hitachi CAS (sold)
Nissan Silvia S14 RB25DE ITB/NA ran MS3/MS3X w/ factory Mitsubishi CAS (disassembled)
Datsun 240z RB25DE ITB/NA with MS3/MS3X
Re: Timing vs. AFR
Gasoline burns the fastest at ~13 AFR, burn speed decreases either side of this point. Since we want maximum cylinder pressure at a particular point in the cycle (15-20°ATDC, slightly dependent on engine geometry), burn has to be initiated at different times for different AFRs. Both leaning out and richening up the mixture from the max power mixture will require more advance for best results. But remember to err on the safe side, you want as little advance as you can get away with to avoid detonation and and the associated problems that follow. The turbo guys often run richer than max power mixtures to slow combustion and increase the margin to detonation.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Re: Timing vs. AFR
They're also trying to cool the mix and the crown (shades of carb'd 2-strokes!).subwoofer wrote:The turbo guys often run richer than max power mixtures to slow combustion and increase the margin to detonation.
