Editing AFR2 table disabled
Laminar
Post by Laminar »
I have a blended setup I configured to allow me to tune MAF since I already had MAP working fine, so I have MAP on VE1 and MAF on VE2, then I adjust table blending to either 0% or 100% depending on which algorithm I want to run.
When I'm in Tune Analyze Live > Fuel VE Table 2 > Advanced Settings > AFR Targets, "Edit/View AFR Table 2" is selected. I can open AFR Table 2 from there and edit it. However, if I go to the "Fuel Settings" menu, "AFR Table 2" is grayed out. Any reason why this is the case?
Also, the y axis of AFR table 1 says "afrload kPa" while AFR 2 is "fuelload kPa", is it supposed to be that way?
Re: Editing AFR2 table disabled
I'd first check to see if the latest firmware has this issue fixed.
Laminar
Post by Laminar »
I upgraded to 1.4.0 and still see the same issue in TS.
When tuning VE2 (which is set to pull data from AFR Table 2), should I use AFR2 Target and AFR2 Error? I'm getting some oddities in the logs, will upload soon.
