Can someone help me with curvs at ITB mode. I need help with 'ITB Load TPS switchpoints' and 'ITB load At TPS switchpoint' curvs. If anyone know haw they must look lets post it.
Here i have one log file
ITB mode
Re: ITB mode
Just make the load at switchpoint 50% across the board.
The switchpoint curve has to be tuned using data from your engine. Basically it should be set to whatever throttle position you're at when you cross 90kPa MAP pressure across the rev range.
