Sync loss? 1500rpm
Sync loss? 1500rpm
Hi guys, after a few year absence I've decided to return to the fun!
I am having an issue with sync loss I believe, car starts and runs at idle alright, but slowly raise the throttle and it gets to 15-1800rpm and starts missing. As you can see in the log. very rich as well.
MS3 3.57 ms3x(ms3 1.3.4 20150123) (tunerstudio v2.6.19)
Car:
'80 Corolla
Engine:
3.0l I6 12v single turbo toyota(6m)
Ignition:
36-1 crank wheel, ford vr sensor, gm ws coils & Quadspark
Fuel: 440cc low imp toyota injectors Any input on what to tackle next? I have played with r56(3 turns cw) and r52(2turns cw) a little now, with no luck. Any direction here would be greatly appreciated!
Car:
'80 Corolla
Engine:
Ignition:
'80 Corolla 6mgte-5spd-8"
Regards
Regards
Re: Sync loss? 1500rpm
can you take a tooth log?
how does the signal look with both pots full ccw?
I will tooth log when i get home this evening and post back up. THANK YOU for your help and responces, really appreciate it.
Regards
Regards
Two tooth logs, one under crank and one running.
Regards
Regards
the tooth pattern around the gap looks funny, not sure if it will help but worth a quick try, change the ignition input capture see if it clears it up.
Falling edge
from full ccw I should adjust r56 and r52 how much at a time? half turns? Trying this again this evening.
Thanks a lot for your time and input!
Rising Edge
looks like rising edge is correct? from full ccw I should adjust r56 and r52 how much at a time? half turns? Trying this again this evening.
Regards
Regards
yeah rising looks like it, you can adjust on a running engine if you are careful and watch the log at the same time
so here is a tooth log of the engine cranking running and slowly reving to its sync loss at 15-1800 or so.
note this is with r56 turned approx 2 turns cw and r52 1 turn cw
Regards
Regards
try a 10k resistor inline with the vr +
10k resistor seeems to have got me reving now!
wooooot! THANK YOU VERY MUCH SIR! Will post a few logs momentarily
Regards
Regards
after the resistor install I went ahead and ran her to verify it worked, then I turned the r56 and r52 back to see if it still worked, and I does, to me my signal looks nice now, can someone please verify?
let me know what ya'll think!
Regards
Regards
id say the zerod logs look good
