Sync loss? 1500rpm
kurtw85
Sync loss? 1500rpm
Post by kurtw85 »
Hi guys, after a few year absence I've decided to return to the fun!
I am having an issue with sync loss I believe, car starts and runs at idle alright, but slowly raise the throttle and it gets to 15-1800rpm and starts missing. As you can see in the log. very rich as well.
mikevisit.msl
MS3 3.57 ms3x(ms3 1.3.4 20150123) (tunerstudio v2.6.19)
Car:
'80 Corolla
Engine:
3.0l I6 12v single turbo toyota(6m)
Ignition:
36-1 crank wheel, ford vr sensor, gm ws coils & Quadspark
Fuel: 440cc low imp toyota injectors
2015-11-01_11.23.30forums.msq
Any input on what to tackle next? I have played with r56(3 turns cw) and r52(2turns cw) a little now, with no luck.
compositeforums.csv
Any direction here would be greatly appreciated! :D
'80 Corolla 6mgte-5spd-8"
Regards :RTFM:
kurtw85
Re: Sync loss? 1500rpm
Post by kurtw85 »
another run log if that helps any
mikehelping.msl
Regards :RTFM:
grom_e30
Post by grom_e30 »
can you take a tooth log?
kurtw85
Post by kurtw85 »
Hope this helps, going nuts over here :RTFM:
Regards :RTFM:
grom_e30
Post by grom_e30 »
how does the signal look with both pots full ccw?
kurtw85
Post by kurtw85 »
I will tooth log when i get home this evening and post back up. THANK YOU for your help and responces, really appreciate it. :mrgreen:
Regards :RTFM:
kurtw85
Post by kurtw85 »
Two tooth logs, one under crank and one running.
crankingafterwork2015-11-02_19.25.58.csv
afterworkIII2015-11-02_19.17.14.csv
Regards :RTFM:
grom_e30
Post by grom_e30 »
the tooth pattern around the gap looks funny, not sure if it will help but worth a quick try, change the ignition input capture see if it clears it up.
kurtw85
Post by kurtw85 »
Falling edge
fallingedge2015-11-03_17.09.11.csv
Rising Edge
risingedge2015-11-03_17.12.13.csv
looks like rising edge is correct?
from full ccw I should adjust r56 and r52 how much at a time? half turns? Trying this again this evening.
Thanks a lot for your time and input!
Regards :RTFM:
grom_e30
Post by grom_e30 »
yeah rising looks like it, you can adjust on a running engine if you are careful and watch the log at the same time
kurtw85
Post by kurtw85 »
so here is a tooth log of the engine cranking running and slowly reving to its sync loss at 15-1800 or so.
note this is with r56 turned approx 2 turns cw and r52 1 turn cw
Regards :RTFM:
grom_e30
Post by grom_e30 »
try a 10k resistor inline with the vr +
kurtw85
Post by kurtw85 »
Will Report Back tonight!
Regards :RTFM:
kurtw85
Post by kurtw85 »
:yeah!:
10k resistor seeems to have got me reving now!
wooooot! THANK YOU VERY MUCH SIR! Will post a few logs momentarily
first_log_postresistor_2015-11-04_19.06.49.msl
Regards :RTFM:
kurtw85
Post by kurtw85 »
after the resistor install I went ahead and ran her to verify it worked, then I turned the r56 and r52 back to see if it still worked, and I does, to me my signal looks nice now, can someone please verify?
let me know what ya'll think!
:D
zerod_2015-11-04_19.41.53.csv
zerod2015-11-04_19.41.29.msl
Regards :RTFM:
grom_e30
Post by grom_e30 »
id say the zerod logs look good
