So, figuring out this stuff on a MS1.
Does using "Use AFR Target table=Yes" disregard "Ego switchpoint V" and use the AFR target table instead?
And does using "Change ego limit above 80kpa" and "Change EGO limit to(+-)=0" effectivily turn of the AFR targets above 80kpa?
I've tried to illustrate it, but i'm guessing you already know the answer
EGO and AFR targets
Re: EGO and AFR targets
what firmware are you using, I don't remember seeing anything like what you are showing on my ms1, post your tune msq and you will be more likely to get help.
http://www.msextra.com/forums/posting.p ... 34&t=61470#
