I have encountered a problem, I am getting random vacuum levels, I have a mechanical gauge and 2 map sensors that show the problem, with the engine idling stable for a few minutes, all the sudden the rpm drops from 1100 to 700 and the afr's go rich , and the map readings rize from 55-60 to low 80's. the engine can be reved up and clear this out but it may come back in 1 minute or 30 seconds or maybe 10 minutes later. I am searching for possible vacuum leaks. but its a change that takes place in about 2 seconds and then will go away with out making any corrections..
in the attached log the problem occurs in the beginning a couple of times, I pump the throttle a few times and let the engine settle out, the engine idled normal at the end of this log for about 3 minutes at 1100 rpm and then the problem repeated itself. I shortened the log to fit so the size limit so that portion is missing.
map readings going high at idle
Re: map readings going high at idle
I had my mapdaddy go out and it pretty much did the same bing if I remember right.. Don't want to lead you astray tho
I was headed towards possible bad sensor, but both sensors are showing the same readings and the mechanical vacuum gauge is showing the same drop. I called accufab yesterday and they said it might be my iac valve, they said they were sending me a new one this Monday, as they got a batch of them with a defect that caused vacuum leaks and mine might be one of the bad ones.
I am still looking into bad grounds and mechanical vacuum leaks. I haven't found the cause yet.
I changed out the iac motor and the problem seems to have cleared up. The last few times I have datalogged the engine the map sensors and vacuum gauge don't show the problem. The iac motor must have been leaking intermittently.
