i have the a ford idle control valve on my 2jz gte vvti running on ms 3 pro ecu, does anyone have the correct settings for the ford icv
thanks chase
2jz gte with ford 2 wire idle valve set up ?
06 z33 with 2jz gte vvti/ bw 369sxe / mspnp pro
Re: 2jz gte with ford 2 wire idle valve set up ?
Ford runs them at 300 Hz. Most of the settings will need to be dialed in depending on your engine's particular intake and airflow needs.
What Matt said. Throttle blade position dictates min and max setting, and cams play a lot with the pid stuff. I run a ford motor on mine and I love it
so wiring it one wire is to a switched 12 sores from the ECU and the other is a signel wire to operate the valve correct.nathaninwa wrote:What Matt said. Throttle blade position dictates min and max setting, and cams play a lot with the pid stuff. I run a ford motor on mine and I love it
chase350z wrote:so wiring it one wire is to a switched 12 sores from the ECU and the other is a signel wire to operate the valve correct.nathaninwa wrote:What Matt said. Throttle blade position dictates min and max setting, and cams play a lot with the pid stuff. I run a ford motor on mine and I love it
Yes. One wire 12v switched from say the coil relay and a PWM output from the Ecu to the ground side. Most ford valves are polarity specific, so if it doesn't work then swap wires
With the wires both ways it just revs to 2500 .
Idk what iam doing wrong
Did you test the valve manually? And have you tried flipping the hoses. If the valve is plumber backwards vacuum can suck the plunger open
