need help tuning
need help tuning
i have a jetta with megasquirt. im learning as i go and have been reading the manual when i have time. i have the car running but is running lean under hard throttle. its a 1.8t with forged internals and a aeb head . I am located in Savannah,GA
i have my current file attached but the log is to big. i can send the file via email
Re: need help tuning
You could try to zip the log and attach that way.
Cheers Luke
Cheers Luke
Thanks. i just tried and its still to big to load
If it is repeatable just make a short log of the problem.
David
David
Your VE values are all pretty low, I'm not surprised that it is lean. How did you come up with that VE table.
Yea, my AEB has higher Ve values, quite a bit higher on every area except close to idle, which are similar.
Check out the peak around 93kpa and 2466rpm and it is low all around it. A peak like that can be caused by Autotune if theses cells are the only ones driven thru consistently. Bring surrounding ones up, and maybe these down a bit.
How does it drive when not on WOT?
Currently Lotus 23C replica Audi 1.8T MS 2 v3 Sequential COP and ignition.
Lotus 7 replica 4age 20V blacktop MS2 v3
For reference, I have attached my Ve table.
I'm not saying it is perfect and I doubt will work on your engine, but might help you.
To get more tuning ability (better resolution) you can change your VE table kpa settings.
From 20kpa to 100 kpa make these the first 12 lines and use the upper 4 lines for boost.
This will give you the ability to tune drive ability much easier.
Matt from DIY said this in another post and it works very well.
As he said 4 lines for boost are plenty.
I reset mine and did a little retuning and drive ability is so much smoother.
David
David
This is a good idea that makes sense. Why not have the greatest resolution in those areas where you drive the most!To get more tuning ability (better resolution) you can change your VE table kpa settings.
jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
