Hi all, I'm trying to get my head round my megasquirt installation on an MX5. It's a 1999 1.8 with bike throttle bodies.
The car hangs on to revs when the throttle is blipped and I can't work out why. I've been looking at some log data but can't quite understand why the DutyCycle seems to be at odds with the pulse width some times. I'd have thought that these two metrics would follow each other. Car is running Alpha-N so pure tps load.
I've added some log output in the hope that someone might be able to point me at the issue and a fix.
Cheers.
Newbie help
Re: Newbie help
Can you post a current msq?
David
David
Re: Newbie help
Yep, sorry. Attached.turbo conversion wrote:Can you post a current msq?
David
Re: Newbie help
What, if anything, are you using for an IAC valve?
Re: Newbie help
It has no Idle control valve.Matt Cramer wrote:What, if anything, are you using for an IAC valve?
I've got it running better by equalizing the ignition advance at closed throttle. There was a large variation and a big jump from 5 deg to 26 deg around 2000 revs. Retarding the ignition over 2000 revs now brings the revs down faster when the throttle is closed.
I'm going to put my vacuum gauges on it and check the balance next.
Re: Newbie help
Didn't download your MSQ but if retarding timing works for you to bring down RPM, have you tried enabling Advanced Idle Setting so you can run less timing during idle, and keep the off-idle timing higher?
