Different tools. Torque measurement gives actual results.
aem dyno shaft
Re: aem dyno shaft
Re: aem dyno shaft
I'd be curious where you are able to get an in cylinder pressure measurement system for £2k...Yves wrote:for that price you are getting close to an in cylinder pressure measurement system, which offers more info for tuning.
Re: aem dyno shaft
I'd say he was referring to thismotthomas wrote:I'd be curious where you are able to get an in cylinder pressure measurement system for £2k...Yves wrote:for that price you are getting close to an in cylinder pressure measurement system, which offers more info for tuning.
jammy86 wrote:The magcanica solution is ~£16000
Re: aem dyno shaft
Ah fair enough. My bad. Even at that you would be struggling.
The idea of having a direct torque measurement on a vehicle is very cool but I fail to see the advantage it would give over a steady state dyno. Even the previous £2k will get you enough dyno time to calibrate multiple vehicles and the result will be most likely more accurate & repeatable than a calibration derived from driving the vehicle on a road or track.
Re: aem dyno shaft
I had an offer for a system US$ 7000. This was with a datalogger with 8 channels and 1 spark plug. Additional spark plugs are around US$ 1500 a piece, but as long as we are talking about tuning, one would suffice.motthomas wrote:Ah fair enough. My bad. Even at that you would be struggling.
I even believe the system estimates power production based on the pressure developed which is not anything out of the ordinary.
The advantage over a dyno shop is that you have the system always at your hands, meaning that you are able to retune if you make changes. And let's be honest, most of constantly change things while we're at it...
I have an old heenan froude dyno here. The issue is that with all the sensory, provisions for cooling water, trying to keep the car cool, a platform to put the car on rollers etc is still a large task, requires place and a load of money to complete.
Re: aem dyno shaft
jammy86 wrote:The magcanica solution is ~£16000 It is very good though and an interesting technology. In F1 it is a homologated sensor mandated by the FIA to keep an eye on the engine performance. The strain gauge ones which are used for driveshafts and the like are wireless. You can get a single shaft done for about £1.5k, the reciever is ~£500 from Texense/texys.
motthomas The holy grail is having an instant torque measurement system for <$500. This is basically taking the idea of MAF replacing MAP to a new level. With some cleaver software you could slap this system on any motor and have it run at peak power all the time with minimal or no tuning.
Re: aem dyno shaft
At the Colorado NHRA Nationals Jimmy Prock showed the strain gauge they used.Matt Cramer wrote:There have been some better shaft-mounted strain gauges developed; one was recently used to measure horsepower on a Top Fuel dragster.
It is mounted around the shaft between the clutch and differential.
He said they measured the horse power at a little over 11,000.
He did not elaborate on the cost but you know it was cheap.
David
