Hey everyone. Because of the issues I am having with my other engine I decided to pull the plugs out of another project car I had built. Basically stock low conpression 5.3l LS with ls2 cam and ls6 intake. Just curious what you guys think of plug color.
Shane
How do my plugs look?
Shane
-1986 Olds Cutlass 370ci 6.0L LS3 top end, TSP 231/236 .641"/.615" 111LSA, MS3x, T56, 8.8, 4.10 Gears, Spec twin disc clutch
-2000 S10 5.3L, LJMS turbo cam, 4L80e, 8.8, S480 Turbo, MS3x
Re: How do my plugs look?
If they look like I think they do then, OH YEA
David
David
Haha thanks David!. I just wanted to make sure I am still learning. That car does pull like crazy so I figured the tune had to be pretty close to ideal.turbo conversion wrote:If they look like I think they do then, OH YEA
David
In a 89 foxbody with a t56 and street tires it runs the quarter in the 12.7x range at about 113-114 mph.
Even with over a 2.0 second 60' ! Only issue is above 6500rpm every now and then it sucks a bunch of oil in from the pcv system and blows smoke like crazy.
Shane
Ah, I thought it was the 86 Cutlass you were working on, how many cars do you have?
On 93 octane and street tires with a 2.33 60 foot I pulled out a 13.13 at 109.87.
You can tell by the mph vs et and 60 foot I can't launch the car, just roll out then stab it.
I have since changed the transmission, first gear is now 3.50 to 1 vs 2.95 to 1.
2nd and 3rd are both lower as well but not as much as 1st.
Of course this is not a drag car by no means but it is quick and gets 19 to 21 mpg town and 25 to 27 hwy.
I checked mileage on a tank of fuel (11 gallon tank) hammer down for the most part and still got 16.5 mpg.
David
David
Haha this is about my buddies car not the cutlass. Die hard ford guy and convinced him to do a LS swap ... but I think it was he wanted to do a 6 speed manual and to do one behind a SBF or modular was VERY expensive.turbo conversion wrote:Ah, I thought it was the 86 Cutlass you were working on, how many cars do you have?
David
I have a crack in one of the welds on my rear end so I need to fix that. Wideband also will not be delivered until Friday. I am hoping by Saturday or Sunday I should have the new wideband installed and reweld the brackets and hopefully not run out of fuel pump...
Shane
I would maybe try a plug one heat range colder. Your 3-4 threads discolored and the goal is 2
nathaninwa wrote:I would maybe try a plug one heat range colder. Your 3-4 threads discolored and the goal is 2
Great! Thank you for the suggestion.
Shane
