so, my ms2 3.57 starts and idles very poorly and doesn't really rev at all. but the d*** thing runs!!!!
now its time to start tuning.
what documentation do I need? I found this that is very helpful and easy to understand, but don't want to be working off incorrect documentation. http://www.megamanual.com/ms2/tune.htm
are there any other good write ups on step by step tuning for blithering idiots?
I have the free version of tunerstudio at the moment, and want to get the registered version for autotune. will this cause any problems for me? any other programs I need?
anybody near charlotte NC that wants to come hold my hand and spoon feed me information in exchange for food and beverages? this whole computer thing is a steep learning curve for me.
what manual? and other questions.
Re: what manual? and other questions.
what firmware are you running? if its the ms2 extra use the manuals at the top of the page by 'quick links'
I'm running msextra I believe. purchased from diyautotune with firmware already loaded.
If you purchased the ecu from diyautotune then it will have the latest msextra version code installed in it at the time you purchased it, simply go to the links at the top of this page and go to the ms2 manuals, one will be hardware the other will be set up and tuning. choose the setup and tuning and use this as your guide to the wonders that is megasquirt.
Good Luck.
Good Luck.
