so, got the duster up and running on ms2. was having a lot of trouble, and thought I was heading down the right path messing with things, but once I fixed the mechanical issue I found out I'm WAY off. in my mind, it would be easier to start with the base map that the megasquirt was delivered with. I bought the ms2 v3.57 from diyautotune. matt emailed me a copy of the installed MSQ earlier today, but when I went to load it o got a warning about signatures not matching. I'm afraid to click the ok button for fear of making an even further mess of things. attached is my current MSQ so you can see what I'm working with, and hopefully you can tell me what I need to do or show me the base msq that the megasquirt was delivered with.
or, alternately, tell me how to take all the tables back to ground zero (before I messed with them.)
thanks
Michael
so im pretty sure i botched it. need advice
Re: so im pretty sure i botched it. need advice
The default, pre-installed "base map" is supplied within the firmware download zip - it is called defaultXXXX.msq.dusterbd13 wrote:or, alternately, tell me how to take all the tables back to ground zero (before I messed with them.)
Or just re-load the firmware and the settings will be back to default.
Firmware can be downloaded from the Downloads page above.
cool.
so apparently mine was delivered with release 3.3.3
will upgrading to the lasted firmware help me in any way? or should I just stick with what ive got?
project is a simple batch fire tuned port HEI8.
