truck is ready for road tuning after YEARS of tinkering. working on accel settings. when I stomp on it ..... it goes. but if I just barley feather the throttle it falls flat. down to a couple hundred rpm. so at the moment I do a lot of baby burnouts
firmware is msextra 3.3.3 e. planning on upgrade soon but wanted to dial in what I got first.
454 truck accel settings
4wheel drive 454 vortec on ms2 w/gpio for 4l80e Trans control
Re: 454 truck accel settings
The AE looks like it's adding a bit too much fuel at low throttle opening, triggering a massive bog.
If you are planning on updating to the latest FW I would do it now.
There are changes in the latest FW so if you do it now you won't have to redo anything.
David
David
Thanks alot. Went with 0 accel below 30%/s and doesn't stall at all. Need fine tuning but 1000% better.
