When to use IAT vs CLT initial steps for closed loop idle
Re: When to use IAT vs CLT initial steps for closed loop idl
The RPM in the table is the target not the actual. The duty should be set to whatever gives you that RPM at that air temperature.
Thanks for the explanation.
No screen shot needed.
I wish all of the tool tips in TS explained things a little bit more in depth yet as plain and simple as you just did right there.
I thought they did in this case. Will see what is there and fix it if needed later.
