What is the default settings for 3.3.x firmware in deg. f for air temp and correction?
David
MAT Air Density question
Re: MAT Air Density question
If you ever want to find the default stuff just open up the example files that come with firmware.
Cheers Luke
Cheers Luke
Thanks for the information and the tip.
David
David
