Boost by Speed issues?
litneon
Post by litneon »
Hey guys! I was wondering if you could shed some light on my problem. I recently changed from Boost by Gear to Boost by Speed to try it out. I'm basing the input as VSS1, which is available over CAN from my trans controller, but it isn't working for some reason. I'm sure it's a simple fix, but I haven't had any luck.
I can answer any questions you may have about my setup....
Thanks in advance!
litneon
Re: Boost by Speed issues?
Post by litneon »
I found that Boost by Speed DOES work in open loop. I'll post up in the development area and see if anyone can help there. I'm wondering if it's a programming issue?
