st170 VVT help
matt311
st170 VVT help
Post by matt311 »
I have an st170 zetec engine ready to fit into my mk1 fiesta which has a standard 1.8 zetec at the moment, running with a microsquirt v3 controller.
Can someone explain how to run the VVT from my ECU?
thanks
Matt
Mk1 fiesta Bravo
2.0 zetec blacktop, st170 bottom end, Yamaha R1 throttle bodies
Microsquirt v3
grom_e30
Re: st170 VVT help
Post by grom_e30 »
according to google the vvt on a st170 is a simple on off type set up kicks in at about 3000rpm. you should be able to use the programmable output to switch the vvt on at your desired rpm.
http://www.msextra.com/doc/pdf/html/Meg ... e-3.4.html
see section 13.10 on/off outputs.
in terms of hardware do you know the current draw of the solenoid? and do you know if it expects a low side (ground) or a high side (12v) to activate it?
matt311
Re: st170 VVT help
Post by matt311 »
grom_e30 wrote:according to google the vvt on a st170 is a simple on off type set up kicks in at about 3000rpm. you should be able to use the programmable output to switch the vvt on at your desired rpm.
thanks for your response, the solenoid takes a 12v feed to activate it.
Mk1 fiesta Bravo
Microsquirt v3
grom_e30
Re: st170 VVT help
Post by grom_e30 »
a solid state relay may be your best plan.
matt311
Re: st170 VVT help
Post by matt311 »
grom_e30 wrote:a solid state relay may be your best plan.
just have a relay that will feed the 12v when i want the VVT to cut in and out?
Mk1 fiesta Bravo
Microsquirt v3
grom_e30
Re: st170 VVT help
Post by grom_e30 »
pretty much the ecu will turn the relay on and off based from your chosen rpm supplying the 12v needed for the vvt to activate. a solid state relay may be the best option though as it turns on and off quicker than a normal and has no mechanical moving parts to wear out.
matt311
Re: st170 VVT help
Post by matt311 »
grom_e30 wrote:pretty much the ecu will turn the relay on and off based from your chosen rpm supplying the 12v needed for the vvt to activate. a solid state relay may be the best option though as it turns on and off quicker than a normal and has no mechanical moving parts to wear out.
oh okay thats sound! Then after that it is just adjusting the degree increase through the rev range?
Mk1 fiesta Bravo
Microsquirt v3
grom_e30
Re: st170 VVT help
Post by grom_e30 »
it looks like its just a simple on/off for your engine so below 3000 rpm vvt is off, and above that its on.
