need help start up nissan sentra b13
I installed ms2pnp and used start up base map, doesn't start. plus my b13 has a sr20det fwd, anyone with info?
Re: need help start up nissan sentra b13
Does it fire at all? Have you tested spark and injectors in "test mode"? Have you verified spark timing? Save me more questions...
it fires, timing is correct, it started now, do you know how to convert a/f to read 147., instead of that .0243?
It sounds like you don't have the O2 settings correct. Do you have a wideband O2 installed and is it connected to the MS?sentra808 wrote:it fires, timing is correct, it started now, do you know how to convert a/f to read 147., instead of that .0243?
Support the developers!
I have a innovate wideband and its not connected to ecu, how would i hook it up to ecu?
Connect the analog output of the Innovate wideband to the O2 input pin of the ECU.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
Wen i download start up program for sr20de fwd, it dont start at all, i changed the maf to map and injector size, and set fixed iming 15 degrees, just cranks and no fire pull out spark plugs and its flooded with fuel.
Can you send tune for my car?
Other than the fact you have a B13 with an SR20DE, how can we build a map if we don't know what you're working with? You mentioned you changed the injector size. What brand and size injectors are you using? Are you using the standard 2.5bar or 4bar map sensor? What IAT sensor did you install?
Please post your MSQ as well as a datalog of cranking to help determine what the possible problems are.
Personal Vehicle:
Personal Vehicle:
I have ms2pnp, im using the 4 bar map built in the ecu, im running the stock 370cc injector, the motor is stock w/ gt28 turbo, I coverted the maf to map using the gm ait.
CRSTune wrote:Please post your MSQ as well as a datalog of cranking to help determine what the possible problems are.
Personal Vehicle:
Personal Vehicle:
Let me clue you in on how all this works in the MS world. We strongly believe in data logs and posting your MSQ. A few years ago we came up with this standard saying.
It won't start is like telling the doctor "Doc it hurts" He needs to know "What hurts, when does it hurt, how bad does it hurt..." That is why we want data logs. And the tune.
Many of us can look at a data log and in 30 sec rule out 1/2 of the potential issues. Examples, If we see the voltage drop to say 9 volts but we see 0 RPM, we know the motor will never start. We have wheel decoder issues.
If we see a solid 300 RPM and we see a reasonable pulse width, we are most likely looking for timing issues or a no fuel pressure issue.
Not to be a jerk but we need logs and MSQ to help.
Andy
Andy
I just need a base tune.. i can do the rest, i used the stock base tune that ms gives and it still wont start.
The stock base tune works just fine if everything is working correctly. We can't help you without real info and data.sentra808 wrote:I just need a base tune.. i can do the rest, i used the stock base tune that ms gives and it still wont start.
-There is no start up map for the FWD SR20DET, just the SR20DE and GA16DE. I'm assuming you're using the GA16 map, is that correct?
-You say it's a stock FWD SR20DET with the stock 370cc injectors but the only turbo FWD SR I know of uses low impedance 440cc top feed injectors. Do you have an RNN14 GTi-R SR20DET?
-Are you using the stock trigger wheel or the DIYAutotune 12-1 wheel?
Personal Vehicle:
Personal Vehicle:
My motor is a u12 motor, stock injector size is 370cc, and idk what map im using, it says sr20de fwd on the megasquirt start up map.
Try this. See what it does (this is NOT a base map). If it doesn't start, hook up your wideband o2 sensor and take a datalog.
For reference, it's a modification of this map (since you wouldn't upload the one you used):
http://www.megasquirtpnp.com/downloads/ ... p_331a.msq
Personal Vehicle:
Personal Vehicle:
Im using stock trigger wheel, but i guess i was informed to use the diy trigger disc, but i dont know what size theres 50mm or 54mm.
MS2 cannot handle the stock wheel properly so you're left to using "basic trigger" which uses the 4 cam teeth for basic operation. This leaves you with batch fire injection and distributed ignition only. It also has poor ignition resolution (4 pickups for 720deg of crank rotation). The MSQ I uploaded is for basic trigger with the stock wheel.
The DIY wheel will improve spark resolution (24 teeth for 720deg) and allow for sequential fueling.
Remove the distributor cap and gain access to the trigger disk. Measure the diameter.
Personal Vehicle:
Personal Vehicle:
so i got the trigger wheel. which one do i choose for the trigger? do i still use basic trigger?
