I see only TPS, MAP/Baro and battery voltage calibration options under toolsCRSTune wrote:Those sound like old instructions. The wideband calibration is located under Tools->Calibrate AFR Table.
starting problems
Re: starting problems
MS1, MSnS extra, PCB v 3.0, 029t
You need to "unlock" the AFR calibration first. This will un-grey the menu.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
Got it thanksCRSTune wrote:You need to "unlock" the AFR calibration first. This will un-grey the menu.
sensoreCRSTune wrote:When you say you did the calibration, are you referring to the calibration in TS or the LC2 sensor calibration?
