I am completely new to EFI and am enjoying the experience so far!
I am installing microsquirt on a 1968 fiat 124 special with a 2L 4 cal engine, plan is yamaha R6 ITB with standard injectors (235cc/m) to start with
Does anyone have a base map I can start with please,
using TS 3.0.16 and MS2 3.4.1
thanks
Ian
base map Fiat 2.0
Re: base map Fiat 2.0
I suggest using the VE generator in TS to get started.
Load in some realistic and maybe a bit retarded ignition advance before starting so you are well away from knock.
Once you get it to idle, slowly increase revs in neutral and tune what you can before 'driving/loading' it.
Add advance later once fueling good.
The docs have a good guide on getting going.
