Injector cleaning service?
Can anyone recommend a good injector cleaning service?
Robert
'53 VW Beetle Street Baja dual port 1641 MSnS-Extra
Re: Injector cleaning service?
Fuel Injector Clinic does a great job! They'll do a pre and post cleaning flow test as well. It helps if you're trying to pinpoint a problem.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
I've had great luck with Eric Durr. You can get his contact info on Yellowbullet.
WitchHunter Performance in Washington state does great work and has a quick turn around also.
David
David
Thanks for the replies.
I have used Witch Hunter several years ago, but they don't return ship to Canada so it is a real pain to get them back.
I did a search and came up with a couple of possible Canadian options.
torontoinjectors.com in Toronto Ontario and precisionfuelinjectors.com in Kelowna BC. Anyone have any experience with either of these?
Robert
Hi,E4ODnut wrote: I did a search and came up with a couple of possible Canadian options.
I am TotontoInjectors owner
I have the latest ASNU test bench and the custom made test bench for big injectors 1000-2000cc
turn around time is 1-2 day - off season.
$30 per injector and free back shipping.
MS3Pro PNP, Mazdaspeed Miata 2004
Thanks. I'll be in touch
Robert
