max air temp with turbo
lotus23C
Post by lotus23C »
Hi, I know the answer is "as close to ambient as possible", but wonder the value when intake temp is too hot.
Currently Lotus 23C replica Audi 1.8T MS 2 v3 Sequential COP and ignition.
Lotus 7 replica 4age 20V blacktop MS2 v3
slow_hemi6
Re: max air temp with turbo
Post by slow_hemi6 »
Too hot once it starts promoting detonation. That will vary from one engine and set up to another.
Cheers Luke
R100RT
Post by R100RT »
Are you utilizing a properly configured charge air cooler?
What temperatures are you developing?
And lets not fail to recognize the benifits of water/ meth injection to eradicate elevated cylinder temps.
1983 BMW R100RT Motorbike
Turbocharged - Water/Meth
Sequential Ignition & Fuel
"Perky Sleeper" that excites bike enthusiasts once discovered (or being passed)
Newest project - 1995 BMW K75 is V3 Microsquirt, "Turbocharger - Of Course"
lotus23C
Post by lotus23C »
R100RT wrote:Are you utilizing a properly configured charge air cooler?
Yes, I'm running an air to air intercooler. The engine is mid mounted under a replica 1960s open top fibreglass body and so there are air flow issues and listening to the engine is also difficult due to massive wind noise.
I'm seeing upto 53C on a 30C day. I think most of my issues are I don't have a decent supply of cold air into the air filter, I am working on that problem currently.
R100RT
Post by R100RT »
That does seem a tad lacklustre on the performance of the air to air.
Cool intake air for ingestion is helpful but more likely it's the cool air flow over the charge cooler core for a good reduction.
Some bikes (check out RB Racing for examples) have the bloody A to A core buried within and having obtuse plumbing tanks and flow redirection but allow enough external air movement to keep the inlet temps in check under high boost.
whittlebeast
Post by whittlebeast »
I get concerned at around 150 deg F. On the jetskis, with the huge intercoolers that we run, we get 10 degrees F over lake water temp at 200 KPA. That is about as good as this sort of thing gets.
benckj
Post by benckj »
53C is not high for IAT temps. Heat soak is a problem with A2A especially with mid engine configuration. Consider going with a A2W IC if this is a problem or add the WI as mentioned above for added benefits.
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
ol boy
Post by ol boy »
I've seen 225F.. 15# no intercooler..
Sent from my SM-G920V using Tapatalk
