Knock sensor testing without running engine
Is there any way to see a readout of the knock sensor data without running the engine. My motor is at the machine shop still and i want to test out my knock sensor wiring before I wrap it all up. Is there any way to output just raw data?
MS3/3x. MS3 knock module.
Re: Knock sensor testing without running engine
As the sensor is simply a piezo resistor you could place it against any machinery to detect a frequency or sound. It won't be accurate to adjust window or sensitivity but may give enough output to tell if it's responding. Trouble is I doubt if MS would display waveform as it only reacts to a threshold vs rpm. Could you attach to another engine block for testing?
Jim
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
It just reads zero. I'm wondering if thats because the engine isn't running.
tap the block lightly with a hammer. Should react.
So it should react even with the engine not running?
MS3 knock sensing only listens during a specified crank angle. You'd have to send it a simulated RPM signal, possibly with a JimStim.
Ok that was my worry. Thanks for clearing that up Matt.
Yes, but I should have mentioned that you need to listen to it with a headphone.aidandj wrote:So it should react even with the engine not running?
I don't have headphones. Its an MS3 knock module. I trust that the knock sensor is working, but want to check the knock module and subsequent wiring.
get the engine running en then tap the block slightly with a hammer in the area where the sensor is. And don't destroy anything of course.
Yes I know. My question was whether or not I could do it with the engine not running.
Is there an answer to this? I am also wondering the same and have hunted around to no avail. At least able to log it to show that the knock signal pulls low or whatever?
87 Dodge Daytona Turbo 2.2 A555 MS2E
99 Dodge Dakota 4X4 410CI 46RE
94 Mustang SB427 T56 FastXFI
See Matt's answer.
