[ts9092 ] autotune input needed
Does it make sense to define the minimum kpa in autotune so it doesnt touch the cells beneath that kpa? I just started to do this due to it initially adjusting my idle and about 40kpa cells. But is there a better more efficient way to do this? My brains fried due to overthinking things.
Efi Tuning Noob, so please go easy on me.
AE92 GZE'd 85 AE86 3dr(blue "cancer" pill)
ATS Racing 2.1 stroker GT3071R 92 MR2t t-top (red pill) DIYPNP w/5sgte in the works
"Nobody listens to Turtle"
Re: [ts9092 ] autotune input needed
Just put minimum rpm to 1200, that's what I do. I don't let autotune touch the idle area.
Graduate of EFI University.
Usually I just lock out the cells I don't want it to adjust.
To lock the cells you don't want auto tune to change right click on them.
David
David
Thank you very much to those that posted, also i didnt know you could lock out cells! Sweet
